So I was thinking about buying rewasd but I live at 2 houses so I have 2 pcs is it that I cant run rewasd on both pcs or does rewasd link to the pc ip and I have to somehow unlink to play on my other computer.
Question about the 1 PC thing
The reWASD has a single instance license key, so it permits installing the software on a single PC. But you may revoke the instance in case of PC or hardware replacement. In this case, log in your personal account and revoke the license to use it again.
To use the software on both PC simultaneously 2 licenses are required.Don't worry! Be Happy!
