all profiles active at once?
This topic is closed.
  • all profiles active at once?
    Hey all, im a bit confused, from the top right of the menu i have created two new profiles / games, for xbox elite series 2 controller, one is setup as a gamepad, the other profile is setup for keyboard rebinds
    but for some reason they are both activated at once and i cannot disable them for some reason? i go to the profile i want to disable, click on the "remap is on" button, to turn it off, then go to the profile i want to enable, click on "remap is off" to toggle it on, and then at the top left corner i select the slot i created the profile in and click on apply, but the one i wanted disabled still has the mappings turned on?
    really confusing
    "Remap ON/OFF" button is a global switcher, it is correct. It works for a single device (controller) and for all configs applied at the moment.
    In order to remove a single config from some slot, please use "remove" icon near the config name in a zone with an active slots, here:
