Started using Shift Modifier on 1 of my paddles cant use it on L2 cuz im playing Valorant everytime I press the paddle(sence is the modifier) and R2(is the left mouse click to shoot) it starts auto shooting even if i dont press it i have to press again to cancel any way I can fix that? Shift modifier is so my sensitivity is lower when im gonna shoot either aiming down sight or not(it happen when i press the paddle and then R2 fast
Auto shotting problem help
Thank you for your question.
May I ask you to share the config file that is used? Please, open Preferences -> MyData - > Configs and select a required folder with config an attach the *rewasd here.
Also, please, try to increase trigger deadzone a bit, like this - https://recordit.co/2EeLIHDv05
Thank you in advance.Don't worry! Be Happy!
