Before Buying Question
  • Before Buying Question
    I am playing a game called Warzone on PC. Would I be able to get aim assit using a mouse+keyboard using this software?
    I installed Rewasd then I imported a config file here:https://www.rewasd.com/community/con...40d7ffda7e21ee
    In Rewasd I made a new profile and imported the Config file. In game I switched my settings to Controller then I turned Remap On
    When I got in game, I couldn't use my mouse or keyboard. I used this site: https://html5gamepad.com/ and it seems as all keys are mapped correctly to my keyboard.
    What am I doing wrong here? I'd like to test this before I make a purchase.
    If gamepad tester shows that both your keyboard and mouse are working correctly, I would advise you the following:
    1. Restart the game, it may not detect the virtual controller immediately
    2. If you have any physical gamepads connected, it is better to unplug them
    3. Restart the launchers you are using for the game
    4. Try to reboot your PC with Remap turned on
    5. Try to change the type of a virtual gamepad. Here is how you can do it:
