Hi reWASD team.
Yesterday I really thought I found the right software to control my desktop with my controller (and avoid mouse/keyboard on my living room PC). After a complex start with reWASD and hours spent on forums (especially this one), I came to conclusion that what I need won't work here.
My target was: I control the desktop with mouse emulation, I launch games, play, and back to mouse emulation when I quit the games.
1st configuration:
- Slots are enable
- Dart icon too
- Focus option in option > tray deactivated
- Xbox ONE controller left stick mapped as mouse, nothing "unmapped"
What happens: Some games still keep focus in desktop mode (Dead cells) and are unplayable. Also when I move the mouse in Windows menu, or Windows 10 menus, white border boxes appears, and select me another icon that the one I focused with my cursor (these boxes are the ones to select an option when using keyboard arrows in any Windows 10 menu). This means a "arrow" input also is applied when I want to make a mouse move.
2nd configuration:
- Slots are enable
- Dart icon too
- Xbox ONE controller left stick mapped as mouse, BUT unmapped option is selected too
What happens: In this configuration, the bug with the boxes selection disappears, and I can navigate in Windows, select all options I want, move the cursor, all works perfectly, till... I launch a game. And because I set "unmapped" on the left stick, the stick simply doesn't work anymore in games.
Conclusion: Or I have white boxes issue under windows + some games don't work, or left stick doesn't work in games.
- Why don't you add an option to deactivate reWASD when Windows 10 desktop focus is lost ? (Controller Companion work like this, except it also has the boxes selection issue).
- Does this boxes bug can be solves, or is there a workaround? As I manage to do it selecting "unmapping", maybe there is a solution ?
So close to have the perfect app, really hope a solution can be find
1st configuration:
- Slots are enable
- Dart icon too
2nd configuration:
- Slots are enable
- Dart icon too
