Elite Series 2 Shift paddle combinations
  • Elite Series 2 Shift paddle combinations
    How do I make it so that when I hold a particular paddle down and then press 'A' the resulting input is a keyboard key such as '>' ?
    I am looking to use my Elite series controller in the same way that its normal shift key works except remap all of my buttons shift equivalents to keyboard bindings instead of controller bindings.
    Cheers.
    1. Please open the Shift layout and select a paddle as the shift modifier.
    2. Inside shift unmap all controls, select A button - > select key combo and enter shift+period to get ">" input, It should look like this - https://recordit.co/ADET8yfR54 (I used the different control as shift modifier cos do not have Elite 2 atm, but the principle is the same)
    In main A acts like A control, press and hold specified paddle you get '>' keyboard input.
    Please check if this workaround is working for you.
