Multikey
  • Multikey
    Im looking to use two controller keys at the same time by pressing one keyboard's key. How can i do that?
    Thanks
    You need to use Shortcuts then - https://help.rewasd.com/basic-functions/shortcuts.html. Select required keyboard buttons and set control mapping (or any required mapping). Pressing buttons simultaneously you get the mapping.
    Also, know that shortcut press time is customizable - https://prnt.sc/t19owf. The less this parameter is, the faster the shortcut reproduces.
      Thanks, but when i try to add "²" (keyboard key) to activate L1 + R1 at simultaneous time i don't understand how; Maybe you can help me more ?
        Thank you for your reply.
        I think I misread you. You need you to press 2 keyboard buttons and get L1 + R1. I thought it was vise versa. Then you need a combo and following steps - http://recordit.co/fJr1Fsl39e
          Thanks to help me!
          So if i understand it well, i need to pay to get this feature right?
            Yes, Combo is the separate feature, that requires a separate purchase. It has 3 days trial period fo testing, then you may buy it if it matches your needs.
