Press key for 2 seconds
  • Press key for 2 seconds
    I want to know how can i press a key for 2 secs just by pressing this key one time. Example: i want to press one time fastly E but i want to ask to the programm to press this key for 2 seconds when i press it one time fastly.
    Thanks in advance
    Let me clarify. Do you want to:
    1. Press E button and the E button fires after 2 sec you've pressed it with certain mappings
    2. You press E and mappings that were set to E are firing for 2 sec long?
    Thank you in advance.
      Thanks to reply,
      The second, press E and firing E for 2 secs
        Thank you for clarifying.
        You need to use a combo feature then. Select the right device - > select required button (E) - > Key Combo. Inside the combo editor set this sequence - https://prnt.sc/t2mycl. Apply the config.
        The E button fires within 2 sec as requested once you press it.
          Ok very nice, thank you so much for your help and reactivity 😘
            You're welcome
