More to the left than to the right
  • More to the left than to the right
    I don't know if it's my control, driver or the reWASD program but my right analog is more sensitive to the left than to the right, does anyone have any suggestions?
    What controller do you use? Does the sensitivity for both sticks have the same behavior with remap ON\OFF? What mappings do you use?
      Configs: https://youtu.be/cNm6XSDCLxQ
      Problem in game: https://youtu.be/q3eYj7nUUbE
        I would like it to go right as it goes left
          This is strange why the movement differs. Nothing in your config seems to be related.
          At the moment, I would suggest you to add a bit more Initial Deflection to the Right Stick (set a bigger grey zone), because seems that the game doesn't detect the small inputs:
          Also, please tune Noise Filter in Advanced Mouse settings, it may also help:
            Is it possible that the problem is in control?
              There are 3 devices in the group, but the R stick is mapped to a mouse, so if you use a mouse as the right stick the suggestions provided by reWASDer should help.
              How do you use the DS4 controller that also added in the devices group?
