Right analog stick is unresponsive
  • Right analog stick is unresponsive
    Imported a custom config and everything works fine except for the right joystick. I am using a regular ps4 controller, please help
    Please, share the custom config link. As I understand the physical DS4 controller is connected and remappings are applied on the controller, right?
    Does the stick work if you create the new config and do the same mappings on the right stick in a manual way?
