Uninstalling Problem
  • Uninstalling Problem
    Hi, I recently tried to use reWASD and it was great but now im done with it.
    the problem is i cant seem to uninstall it
    it is stuck on the unistalling screen
    any thoughts?
    How does the uninstalling screen look like?
    Do you have any antiviruses running the background? Please disable them all temporarily. Also, try to run the uninst.exe file with Administrator (C:\Program Files\reWASD).
