Hello, I just installed reWASD because I’m unhappy with how the PS4 controller is set up for Green Hell. I’m playing it through Steam and wasn’t able to reconfigure the controller successfully with it.
After experimenting a bit I’m still not being able to make it work. Here are some questions that came up so far:
1) How does reWASD work exactly? Does the program have to be running in parallel/background with the game or is it just used to configure the settings and create a setup file that is then used by Windows?
2) Are there any more detailed instructions on how to use reWASD with Steam games?
3) Is there any conflict between reWASD and Steam configurations for the same controller?
4) Are these questions already answered somewhere in https://help.rewasd.com/ ? If not, can this information be added there?
