Hi, I'm struggling to find a way to do what I want. What I want to do is be able to use R2 exactly as I normally would, a press of the button operates just like it would normally, no delay for anything, if holding the button does something then I'd like that action to work while I'm holding the trigger, at the same time I'd also like the button, if I double tap hold it, to then turbo.
I.e. if I'm using an automatic weapon and hold the trigger it fires full auto as it normally would, if I'm using a semi-automatic weapon and I hold the trigger it fires one shot then nothing, but if I'm using a semi-automatic weapon and double tap R2 and hold then I'd like the trigger to turbo fire
I tried with the double tap button press and single press but that causes a delay because obviously it wants to know whether it's a single or double press, I don't want this delay though and I want it to assume it's a single press unless it receives a double press in which case switch function to the double press method.
I also tried using the start press as well as the double press but that doesn't hold the trigger, it presses the trigger once so if I use an automatic weapon and just hold R2 it fires one bullet and then does nothing.
Any help to achieve what I want would be greatly appreciated, thanks.
