I have set up how to edit and shoot and everything fine on aim asssit on kbm but my only problem is how do I make it so that I done have to press switch mode everytime I build how do I make it so that I can build instantly like kbm help is appresciated
BUILDING BINDS FOR AIM ASSIST ON KBM
Perhaps this information would be useful.
reWASD has a feature called Activators. And you can map a key on Start press (the mapping will reproduce at the moment when the button is pressed), Single press (it's a regular mapping that reproduces after the button and pressed and until the button is released), and Release press (this mapping reproduces after you release the key)
In the case of building in Fortnite we have come up with an idea to map:
B to Start press
LB/RB/LT/RT to Single press WITH Turbo
B to Release press
What happens in-game: after you press the key, you go to build mode because of B on Start Press, then LB/RB/LT/RT is Toggled to build continuously, and when you release the button B reproduces to get you out of build mode.
This is how it will look in reWASD: https://recordit.co/NJw1FdEKDJ
You can change the Turbo pause to an amount that is comfortable to build."Don't worry! Be Happy!
