Mouse Problem
  • Mouse Problem
    If I move the mouse fast, the movement is slow, if I move slowly, the movement is fast. I can't turn around quickly due to this problem. (Remote play)
    Because sticks do not work as a mouse does. To turn the character from side to side quickly, you need to hold the stick for some time at the maximum point of deflection. Which, in case of mapping the stick to a physical mouse, is equal to slowly, but consistently, moving it in a certain direction.
    I would recommend checking this link explaining everything regarding the stick being mapped to a mouse.
    Also, check the in-game settings. First of all decrease to minimum move stick deadzone, look stick deadzone, fiddle with look sensitivity. In-game settings are important as well and give you even better gameplay that reWASD settings only.
