PS4 Bot in Python
  • PS4 Bot in Python
    I am creating a bot that will work on PS4 Remote Play. I need to simulate a key press on a gamepad.
    With reWASD, I remapped keyboard keys to gamepad keys. For example 'space' = 'X'. But I can't press 'X' in Python because pressing 'space' is simulated.
    Perhaps in the code I should use not 'space', but 'X'... I do not know how to do it. Maybe there are some code names for the gamepad keys so that Python would understand them?
    It won't work. reWASD works with physical devices only, but the Python code emulated virtual keyboard input (i guess), which is ignored by reWASD.
    Unfortunately, I can't help you with this question.
