Nintendo Switch Poke Ball Plus
  • Nintendo Switch Poke Ball Plus
    hello, i am wondering if the poke ball plus on the nintendo switch can be supported to assign hot keys in the future? it's a very cheap controller and it has an A & B button with a jotstick. the controller also has built in gyro. thanks for your time!
    Well, can't tell you for sure. But, we will take it into account, thank you for the suggestion.
