I turned on this feature, with loop enabled. Once it triggered, I was unable to change the type, uncheck loop, or disable it. It would also be nice to be able to adjust at what percentage this happens.
LED when battery low issue
Not sure what exactly is happening.
If Loop is on, reWASD will send the chosen light and mode to your LED until it get an info that the battery is more than Low or once you start charging it.
If you want to change settings, go to Preferences, choose the devices, make changes and Apply them. Is that what you have done for your controller type?
Not all controllers report the percentage. Which one do you use?It would also be nice to be able to adjust at what percentage this happens.
Yes, I did just that, but nothing would actually apply. It stayed with the initially selected light, mode, and color and wouldn't change. The gamepad in question is the Dualshock 4, and the point at which the indicator goes off is at least a third of my actual battery life. I use my controller until the battery actually dies, and the percentage seems very bottom heavy. Meaning I still get hours of play when the bar would indicate otherwise. Being able to change the point at which the indicator begins would allow me to solve that.
The full list of changes is
