Xbox Elite Controller Series 2
  • Xbox Elite Controller Series 2
    I'm not sure if reWASD is working the way I would like to, so I'm asking here.
    When playing a game on Xbox with Xbox Elite Controller Series 2, the game has keyboard shortcuts (e.g. C) for actions. I tried to configure the controller as described and was able to put the C key on one of the paddles. But when pressing it playing on my Xbox, it doesn't work. So does reWASD only work for using the Controller on a PC but not vice versa (programming the controller for use on Xbox)?
    -Nick
    reWASD installs on the PC, mappings work for PC games and apps only at the moment. reWASD doesn't interfere with controller's firmware, so you get default bindings when you connect to the console.
      Thank you. Do you know any other software which maps to the console?
        I'm sorry, but I don't know, so can't tell you what software you should use best regarding your demand. I play on PC mostly.
        May I ask you to specify what game requires the keyboard shortcuts on the console?
        Thank you in advance.
