weird mouse movement axis 2 stuck
  • weird mouse movement axis 2 stuck
    So, i am trying to play on ps4 remote play with virtual controller, with mouse and keyboard.
    And when i am use https://www.rewasd.com/community/con...ard-and-mouse/ this config my camera driving crazy and cant stop moving around.
    Because my axis 2 are stucking in one position:
    Click image for larger version  Name:	stuck.jpg Views:	128 Size:	78.7 KB ID:	221158
    why did this happen? (
    thanks!
    Unfortunately, the config link is broken. May I suggest you use this config for remote play.
      sorry, this one works fine:
      [link expired]
      i am just trying to understand, why did this happen...
      thanks!
        Perhaps, some mappings on zones, too small deadzone, super big sensitivity... The community has lots of remote play config, so you have options to test.
        Meanwhile, this video guides you.
