In Destiny 2, my character wont stop spinning
  • In Destiny 2, my character wont stop spinning
    In Destiny 2, when i remove my mouse from the mouse pad or give it a hard swing, my character start aggressivly spinning and the only thing i can do is to turn off the remap.
    Any suggestion on how to fix this problem?
    Do you use the mouse as the right controller stick? Please, check and remove the mappings from zones in mouse directions? You may find it here
