Mapping question
  • Mapping question
    I might be being silly, and missing something.
    Using m/kb.. I want to be able to turn rewasd off whilst in game via a mapped key. Thanks.
    In case you use the keyboard and mouse remapped to the controller use shift to switch inputs. The standard config has a Shift 4 remapped to a "Win" button that cancels the controller input, the KMB became available to use. Press the "Win" button again to back controller input.
    Is this workflow you need or you want to completely turn off remapping in the game?
      Thanks but yes I'd like to completely turn it off. Ideally it would be nice to be able to turn it back on again. At the moment I have to shift tab out of the game and do it manually.. Which is far from ideal.
      Thanks for the reply.
        You may use ctl+alt+del that turn all mapping or map some button to remap off command that disables the remap for a chosen device or group of devicesÑŽ No command to remap ON, but you may use another solution - Autodetect - apply the config while the application is in focus. More details are here
