DS4 Movement - Remapped Keyboard movement.
  • DS4 Movement - Remapped Keyboard movement.
    I'm trying to record a stick movement with my DS4 controller, however REWAS doesn't recognize the movement, just the key presses.
    I looked on the forum and saw a topic from January where somebody said it's a feature that will be implemented in the future. Has this been released yet?
    If not, is it possible to record keyboard remapped movement? Example: i press the left joystick up to move forward. In ReWASD i press W to do the same movement. Can I record W as a key?
    Currently, reWASD doesn't record stick inputs, so, you need to enter it in a manual way. Other controls are being added automatically while recording. We plan to implement it in the near future.
      Nope, you can record only physical keys and buttons.
