Dualshock 4 - key combo
  • Dualshock 4 - key combo
    I've just bought a key combo feature and I have a problem. Can I make a combo with arrows and mouse movement? I would like to use my right stick as a mouse and arrows at the same time.
    For now the combo does not support the mouse movement, unfortunately. You can use the stick for mouse movement, but you cannot include the mouse movement to the combo.
      What you can do, is to make 2 different Shift Layers, in the 1st one you can map the stick to the mouse, in another one you can map it for arrows.
        Oh, okay... I hope that they add a support for this. Thanks for answer!
          We for sure will add this feature to reWASD sometime. But for now this type of combo is not supported. But we will improve the combo in the next reWASD version. You will like it and you won’t regret the purchase 😉
