I built a config to counter recoil for a certain gun in warzone. It works well except for randomly (I say this because I haven't been able to link it to a specific controller action) the right stick will completely lock up, and to unlock it I have to change to a different config slot and then back via the shortcuts. Any suggestions on why this might be happening are appreciated. The config is attached.
Config Explanation:
All:
The left stick click mappings just make it so it automatically tactical sprints (double press)
Shift 1:
There is a shortcut on LT and RT which triggers a downward right stick movement
RT is bound to RT as well as waiting a certain amount of time and modifying the RS movement.
The other shortcuts allow for me to still move RS smoothly while the actions are happening.
Cheers!
Config Explanation:
All:
Shift 1:
Cheers!
