pc going to blue screen whenever i try to install
  • pc going to blue screen whenever i try to install
    so i tried to install re wasd and i click reboot now to finish installation and then i get a blue screen saying page_fault_in_nonpaged_area and i have to boot into safe modem uninstall the software then go into normal windows. this happens everytime i try to install
    Do you have a dump file of the BSOD? Usually, it stores %SystemRoot%memory.dmp i.e C:\Windows\memory.dmp. Please, check it and send us a dump file to find the BSOD reason.
      idk if this is the right dump file but here it is
        Hi there,
        Check the dump file and looks like the problem with the AswArPot.sys.
        "fffffe08`59d7a7c8 fffff804`4c104001Unable to load image \SystemRoot\system32\drivers\aswArPot.sys, Win32 error 0n2
        *** WARNING: Unable to verify timestamp for aswArPot.sys
        aswArPot+0x14001"
        The process known as Avast anti-rootkit belongs to software AVAST Software s.r.o by AVAST Software (www.avast.com). Maybe this link will be helpful.
