when I use my PlayStation 4 controller the mouse every 2-minutes just go up to the corner to the x so sometimes if I click I close down windows because it goes up to the x is it happened after I updated windows what can I do to fix have you encountered this ?
PlayStation 4 controller the mouse every 2-minutes just going up to the corner
so I found out that one profile where there was a mouse mapping every time I used it in a certain way it went up in the corner, I tried to unmounted but it didn't work I couldn't see anything other than the mouse in the profile mapping so I don't know what went wrong what what helped me was making a new profile even though it took me an hour to take all the keys in
There are a couple of things you should try:- Clearing a sort of 'Gaming cache':
2. Click Clear data button and confirm your action
3. Wait until the GUI and tray agent appear
4. Initialize your devices from scratch and try again- Reinstalling the software.
I wanna try that next timeif it happens again it works now after I change the configuredOriginally Posted by wookiepediologist View PostThere are a couple of things you should try:- Clearing a sort of 'Gaming cache':
well it happened again it work for a time
I have try to do one you described
1. Go to Preferences (a gear icon at the bottom right), General tab
It looks like the issue with a config then. I can try to check it on our side.
Please send me the config you are using. Your configs are stored here: C:\Users\Public\Documents\reWASD\Profiles ​​​​​​​I need the correspondent *.rewasd file.
Hm, nothing strange I have found there. Also, I could not reproduce the issue with your config. Seems to be working as expected.
I think the new config made from scratch may do the trick, because your one is truly pretty complex
Also, I would recommend you to check any other mapping software you may have or maybe installed before. Let's say, Steam also has an embedded mapper that is active even on desktop. It may be a chance that both configs (the one from reWASD and from another mapper) lead to this issue.
I don't think so it's call ROCCAT Swarm and it came with my mouseOriginally Posted by Star-Lord View PostHi there,
Disable the controller support in Steam big picture (Settings - > Controller Settings - > uncheck your controller).
Is this native software of the mouse vendor you were mentioned in the last post?
I do not have the option to uncheck the controller in Steam I can see the controller but no checkmark but I was able to disabled Rumble effect and joystick navigation I don't know if that you meant
you can see it in the video I recorded
