NIntendo Switch HD Rumble/or Rumble Calibration
  • NIntendo Switch HD Rumble/or Rumble Calibration
    I did manage to use my Nintendo Switch controller with ReWASD, and I was thinking if there was some way to either choose the rumble power (HD rumble) or even reset its rumble capability if its has been maybe altered by a previous 3rd party driver (which kinda appears to be one my controller case and official linking to Switch doesn't fix it).
    Thank you very much for taking my issue/suggestion into consideration and your knowledge/time
    Best regards,
    Hi there,
    reWASD allows you to manage rumble. You may opt for rumble duration, which motor is used, and set rumble strength. No extra drivers are required for that - https://recordit.co/9LQvjocLRT
    Have you tested?
