Okay so, I’ve been searching for almost a day now, and I cannot find a custom configuration for warzone that emulates the default bumper ping settings.. like being able to put on armor or pick up a weapon or even if I wanted to call in load out box. Someone please help, thank you!
COD modern warfare Warzone Default button layout
Thanks for the reply, I haven’t had issues per say, more of understanding which control for example if A is for jump and on the keyboard it’s space then I would put that. Now for putting on armor plates, you would normally use Y but it says “unbound†which means that action hasn’t been assigned a button. I don’t know how to assign actions that haven’t been assigned yet like putting on armor plates or how to use an armor or ammo box which would usually be RB and LB together. I guess I just don’t know how to map or assign those actions. I was hoping to find a configuration already done where I wouldn’t have to go back and assign buttons. Any advice or pointers would help.
The easiest way to create a config from scratch is to open in-game settings and check all the bindings you see there.
Let's say, Jump is Space and A. So, you need to map A to Space, you have got it right.
Yep, this process may take a while, but you will get a config that suits you best.
Also, visit the link from Star-Lord's post, there are many ready-to-go configs there, so you may use them at least as a basis.
i'd love to get your setup for this (maybe you can take a photo of it) this has been a struggle- i also use bumper ping and there are a few things i'm having trouble with for the remap- any help would be appreciated!!Originally Posted by Vcr500524 View PostI will keep that in mind, happy thanksgiving 🦃 y’all! 💪ðŸ½
