Rumble while holding trigger down
  • Rumble while holding trigger down
    Hey I feel this may have been asked already, but I’ve had trouble finding an answer.
    Is there a way to get the rumble to continue as long as a button is being held down?
    I use REWASD for ArmA 3 with an Xbox Elite v2 controller and I absolutely love it, but it’d be great to have constant vibration during automatic fire instead of a timed vibration that is semi-automatic.
    Does anyone have any ideas on how to achieve this?
    Well, for now there is no such an option in reWASD, unfortunately.
    Right now you can only select the value in ms so it will be reproduced for the specified time only.
      Hi there,
      You may use try to set a combo with mapping + rumble inside and set turbo, like this - https://recordit.co/4wiW83kzbb. In this case, the trigger fires with a rumble until you held the button.
      So if you need to press\hold button for more than 2 sec - it will also work.
