I just installed rewasd few hours ago, and after configuration i realized everytime i switch between differents profiles with the profile button on the gamepad, all key bindings crash.
What happens:
- Only the Xbox button works after crash, all the others buttons does not work (when i press them, nothing happens - for profile button the gamepad led continue to work and indicate a profile switching)
- Crash happens in bluetooth and with wire
- If remap is off, there is no problem
- Sometimes i can change 5 or 6 times of profiles, sometime 1 profile switching generate a mapping crash
Is it a known issue ?
Lithiumx.
What happens:
Lithiumx.
