Mouse Stuttering
  • Mouse Stuttering
    hello,
    I have this problem with the mouse when I move it, I show you in video
    (sorry for the quality)
    thanks
    Hi there,
    Your mouse is unmapped, the game constantly changes inputs from mouse to controller. It's seen when you move the mouse (RB\LB controls on a top). Unmap the mouse including the mouse movements to exclude the multi inputs.
      when i unmap the mouse including the mouse movements, mouse no longer works, only wasd to move work
        Hi there,
        The unmapped mouse acts like a right stick. Please, check if the advanced mapping feature is active. Also, make sure that the mouse is detected correctly in the reWASD (here is a video showing how it can be done).
          still not working, i test all,
          it works fine with wasd keys, but not with mouse
            Your videos show that game switches constantly between controller and KBM controls. You have to set the [Unmap] flag for every mapping (both mouse and keyboard) you made in reWASD to avoid that. That flag requires [Advanced mapping] feature license or trial period activated, so make sure you've got it first.
            Click image for larger version  Name:	image_2493.png Views:	5 Size:	65.4 KB ID:	222786
            Once you've set [Unmap] flag for all mappings, follow this article to set up "manual switch" between virtual gamepad and KBM controls.
