Need help to exit the programme, Plz
  • Need help to exit the programme, Plz
    The reWASD launch when I start windows, I try to right click on the right bottom icon and exit, but when I click the icon, the option just blink for like a second, so I can't click exit.
    How can I fix this problem?
    Well, this is obviously some windows failure, not related to our software directly. Something is not allowing to show the context menu.
    If you want to disable launch when windows starts you can do it by entering the Task Manager - Startup - Disable the start for reWASDTray.
    Try reinstalling the app as well, during the installation select custom install options and uncheck the start with Windows if not necessary.
      thanks a lot man
        Not at all, always glad to help <3
