SO I basically bought this to play GTA V online with keyboard and mouse and during the trial, it worked great. I did not change any settings at all.
Then I guess the shorter background trials for the advanced mapping etc.. stopped cause all of a sudden the mouse would not act as the right stick anymore. Finally figured out the trial was the issue.
Being impressed with the function of it, I went ahead and purchased the advanced mapping feature and the main program. Activated it.
At this point the mouse would be stuck on moving me left or right. I found that video posted on the fix, did the fix and then it worked again for about 10 minutes. Essentially if I reboot my PC, it would work but then as soon as I was rapidly inputting buttons say when running and shooting simultaneously, it would suddenly break and the spinning would start again but not stop until I reboot my computer.
I eventually fiddled around with the settings enough that it stopped, but now I can't move while aiming (Move the mouse no longer moves the curser when I have the right mouse button pressed so that my toon is aiming down the sight of his weapons') which is essentially means I cannot use the feature. I seem to be stuck between non-stop movement or lack of aim.
I am attaching the config file here as I believe that would be helpful.
