where are the fortnite configs ?
  • where are the fortnite configs ?
    hi
    So i recently installed this software in order to play fortnite free of the unfaire bloom and low shotgun damage
    but i cant find a config?
    i use a xbox 360 controller
    Hi there!
    Check out our community section. It has all the configs shared by our users.
      thank you
      i will watch it
        i find it a few complicated
        isnt there a way to remap my mouse only so the game will think i'm pressing a controller button when in fact left or right clicking my mouse?
          Yes. Select the mouse and its buttons on [Mouse] sub-config and map them to whatever buttons you need. Don't forget to set [Unmap] flag for those mappings, because otherwise mouse clicks and movement will still be passed to the game.
          Note that you will need [Advanced mapping] feature activated for that to work. Buying a license or starting its free trial period of 3 days will do.
            too complicated
            remapped lft and right click to l1 l2
            but it fucked up all my windows
            had to restart it
              Unapproved ?
                It seems difficult at the first sight. YouTube tutorial explains everything.
