Map Slow Trigger Pull
  • Map Slow Trigger Pull
    I'm playing Red Dead Redemption 2, and in the PC version they removed the 'slow draw', which was present in the console versions. This is due to the fact that, to use it, you have to slowly pull your trigger down. I'm trying to bring that back by mapping the Right Trigger to the mouse, but I can't find any option to map the slight trigger pull. Where can I find this?
    You'd need to have an [Advanced mapping] and [Combo] features for that. In [Combo] it is possible to set value for a trigger, so you'd need to make a [Combo] in [Hold until release] mode, similar to this one:
    This [Combo] will add 25% to the trigger pull each 500ms. You can add more steps and make pauses smaller for a more smooth trigger-pull effect.
