I'm trying to setup custom channel points on my Twitch channel, where a viewer can spend channel points to remap my controller.
I have tried this in every single way possible. I use Lioranboard twitch integration which works fine.
First, I set up the different mappings (I've tried this both as shift controls and in different slots) and the shortcuts needed to changing the mapping. (One example was setting F11 to be the shift control, the other was setting Shift+F1 to be a slot shortcut). This has worked fine every step of the way.
I then used Lioranboard to setup a keyboard macro when someone redeems a certain channel point reward on my channel. For example, using F11 as a shift controller, when F11 is set o be triggered by Lioranboard, on channel point redeem, OBS went into full screen mode. This also worked.
However, no matter what I do Lioranboard can't trigger the changes in ReWASD.
I've grouped my controller with both keyboard and mouse, trying MANY different hotkeys in attempts to trigger this and it hasn't worked.
I've tried this running ReWASD and Lioranboard in and out of admin mode
I would really love to set this up for my viewers, can anyone please explain why it doesn't work?
