I'm pretty sure the way I'm using rewasd is not something most of us using the program do,
I'm using rewasd to get gyro support for my controllers while using a game streaming program, like Parsec or Moonlight - actually I use both so for the 4 limited slots I use a config on the client.
1) Desktop 2) Gamepad 3) Gamepad + Mouse gyro 4) KBM config <- this is where I get issues, more on that later.
Once connected to my host using either Parsec or Moonlight, I have another rewasd installation with a license, for both my client and host mind you.
Each and every game on my host has its own config and gets applied automatically with the nice feature of associated app (Auto detect) - I love this, amazing job!
Then I just have to use my gamepad combination to switch to the desired config on client, gamepad, gamepad with mouse gyro or keyboard mouse (If more slots was a possibility I wouldnt have this problem) but I guess, most of the users dont have this problem to begin with because they probably dont hide their gaming pc in the garage due to noise levels
On to the problem, when I set the gamepad and unmap all the controller even with a config applied on host doesn't get an output at all, its like the controller doesnt exist anymore.
Fine, I thought so I made a new KBM config, this time with Left,right mouse click on the triggers - this worked suprisingly well but only for games that support mixed input - much like the gamepad + mouse gyro, but thats not exactly what I want for this config, I need a config thats KBM fully. So I added a "." to every mappable key and applied the right kbm config on the host but this instead output both the client binding "." and the host binding in this example "E", opening up a wordpad on the host it would type out ".E"
Since unmap didnt work and the . did work but it sent two outputs. Is there a way to have like a empty binding?
Is anything of this making any sense to you? Haha, yes I know. This is an odd way of using rewasd but since neither parsec nor moonlight support gyro - this is the only way I can think of.
Thank you in advance!
PS. I would absolutely love more slots, they are awesome and I would really like alot more, if its possible that is. Slots and auto detect, wow. amazing!
