Hey everyone, sorry english is not my first language, so i'll do my best.
When i Launch the Installer, NOTHING opens ... i tried in normal mode, as administrator, i even did reboot my computer many times..
I already bought the license because i tested REWASD at my friend's home.
When i Type "rewasd" in my windows search bar, i can find "rewasd installer TextTrace"
here is what is in this file
"reWASDInstaller: 00:22:13:565 reWASDInstaller got Unhandled Exception
reWASDInstaller: 00:22:13:566 CallerMemberName: CurrentDomainOnUnhandledException
reWASDInstaller: 00:22:13:567 Exception type: System.IO.FileNotFoundException
reWASDInstaller: 00:22:13:567 Impossible de charger le fichier ou l'assembly 'System.IO.Compression, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' ou une de ses dépendances. Le fichier spécifié est introuvable.
reWASDInstaller: 00:22:13:572 à RewasdWpfInstaller.Utils.Helper.ExtractZipArchive( String folder, Byte[] zipResources)
à RewasdWpfInstaller.App.OnStartup(StartupEventArgs e)
à System.Windows.Application.<.ctor>b__1_0(Object unused)
à System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Int32 numArgs)
à System.Windows.Threading.ExceptionWrapper.TryCatch When(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
à System.Windows.Threading.DispatcherOperation.Invok eImpl()
à System.Windows.Threading.DispatcherOperation.Invok eInSecurityContext(Object state)
à MS.Internal.CulturePreservingExecutionContext.Call backWrapper(Object obj)
à System.Threading.ExecutionContext.RunInternal(Exec utionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
à System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
à MS.Internal.CulturePreservingExecutionContext.Run( CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
à System.Windows.Threading.DispatcherOperation.Invok e()
à System.Windows.Threading.Dispatcher.ProcessQueue()
à System.Windows.Threading.Dispatcher.WndProcHook(In tPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
à MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
à MS.Win32.HwndSubclass.DispatcherCallbackOperation( Object o)
à System.Windows.Threading.Dispatcher.LegacyInvokeIm pl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
à MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
à MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
à System.Windows.Threading.Dispatcher.PushFrameImpl( DispatcherFrame frame)
à System.Windows.Threading.Dispatcher.PushFrame(Disp atcherFrame frame)
à System.Windows.Application.RunDispatcher(Object ignore)
à System.Windows.Application.RunInternal(Window window)
à System.Windows.Application.Run(Window window)
à RewasdWpfInstaller.App.Main()
Can you help me ? ...
