I just bought the software and it works find. Hower, only in Multi-player not warzone this annoying "using KB&M, visit options to change. As if it's trying to detect a controller but buttons are mapped to be keyboard functions. It does the same thing with two aftermarket Xbox controllers. One is the razer wolverine ultimate and other is fusion by power. Thanks for any advice?
Annoying mouse and KB message keeps popping up in upper right hand corner, COD MW
Just make sure you use all keys which are remapped to the gamepad keys.
Also, you need the unmaps feature enabled for all the keys you use.
