Remapping mousewheel to a key
  • Remapping mousewheel to a key
    Hi. Im playing a game called Runescape, and it takes 4 long scrolls to zoom out from furthest to closest. That is at their max zoom setting. However you can use Page Up/down instead, and it goes much much faster. I managed to bind keys to the mouse wheel, but not the other way around, i cant find it anywhere. Anyone got some ideas? I would like it so when i scroll it clicks pageup/down either instead or both at the same time. Thanks
    I suppose this is what you're looking for:
    Keep [Unmap] flag on if you want only for [Page Up/Down] buttons to be sent.
