I am facing some problems with my HDD which the program IS NOT INSTALLED ON SAID HDD (yes even the profiles are not on it), but for some reason, reWASD won't launch unless I plugin my HDD. So, i decided to reinstall the program, but even the installer won't start unless my HDD is plugged in.
Installer won't launch
Please check for errors in Event Viewer following the steps below:
1. Press Windows button, type 'Event Viewer', press Enter
2. Choose Windows Logs in the upper left corner, then choose Application
3. Check out the panel on the right side: there's a Find option. Click it, and type 'reWASD' to search for related errors
4. Once you find one or multiple events, please right-click them, and choose 'Save selected events...', and send them to us.
