mouse not work
  • mouse not work
    hello i need help when i press in my config remap on my mouse freeze and my mouse doenst work thank you
    Once you apply a config with a virtual controller, your mouse and keyboard should be blocked, because otherwise you will get a double input in a game, and it is unplayable. I assume this is exactly your case — you are using a config with a virtual controller.
    You can switch between two inputs easily. If you are using our default PS4 Remote Play config or any other one that is based on it, you will just need to tap Left Windows keyboard key to get your mouse back and tap again to switch to the controller mode. There are a few other methods for this case, you can check them here. It may be a chance that something is not adjusted properly in your config at the moment, so please use Ctrl+Alt+Del hotkey on your physical keyboard for the emergence stop: the remap will be turned off, and you will be able to get your devices back and check the settings.
