I've read some other threads, but can't get it to work. I want the the Gyro to only be enabled whenever my thumb is resting on the touchpad, and disabled when it's not. I've mapped the toggle to start press and release press, but I get the opposite behavior (Gyro is on when my thumb is not touch the touchpad, off when it is). Ideally there should be separate On and Off controls for the gyroscope, instead of a toggle.
How to enable Gyro only while pressing right touchpad (Steam Controller)?
You can either map gyro to something at main shift, and disable that mapping on another shift, while making that right touchpad into a shift modifier. Though I don't remember if setting touchpad as shift modifier is possible right now.
Another way would be to map [Toggle Gyro On/Off] command to right touchpad via both [Start Press] and [Release Press] activators. Commands require Tray Agent to be enabled to work.
