Force Stick drift
  • Force Stick drift
    Hello rewasd team , I use mouse mapped as a right Stick .. there is a way to force Stick drift when my mouse is not moving (just a little) ... I tried disable spring mode but the drift is too high and no consistency , and I cant reduce the drift to like 3% ... tried spring mode on and lowest deadzone posssible , tried custom curves with the First point in 0 deadzone and sometimes drift , sometimes not ...I want a fixed low drift ... sound strange ... but if you guys know how to do it , i’ll be glad... thanks
    Check if you have any zone mappings set for the mouse (can be seen at [Advanced] settings of the mouse mapping). If there's none, try rising deadzone setting in the game or lowering [Deflection low] value at [Virtual gamepad settings].
      hello shion , u mean with spring mode off?
        No, but you can try both on/off to see what works best for you.
          spring off And a did what you tell me ... thank you so much , it works
