I've been using the Key Combo feature on an XBOX ELITE 2 controller. For the most part it works fine, however, it seems that sending changes (APPLY) does not work more than 1 out of 10 or 20 times as the key combo gets longer. I go in to adjust a minor tweak (reducing or increasing delay, adding a new input) and most of the time APPLY does not properly apply it to the key combo that is represented in game. I can tell because I have button display on in the game I'm attempting to use it. I add an errant button at the end to see if it registers and plays once APPLIED. Most of the time it does not. I have to seek APPLYING and trying again over and over. Sometimes it takes up to 20 applications to even see the change properly appear in the playback of the Key Combo.
So far, I love the product (I'm on TRIAL version) but if it constantly takes 10-20 tries to make a single update, it's not the program for me. I'm hoping this is a bug or something that can be fixed.
Thanks in advance!
Thanks in advance!
