"Toggle Remap on" shortkey.
  • "Toggle Remap on" shortkey.
    I just changed the shortcut to toggle remap off for a single key so i can get my mouse back quickly while in game to select stuff that requires a mouse, but is there a way to turn Remap on the same way (With a shortcut key) to toggle it back to controller mode instantly?
    Like keep switching between the two modes with one click.
    Nope, at the moment, you can't turn remap on if it is off, because when it is off reWASD is not working actually.
    However, I have a few other ways to get similar behavior. All of them are described in this post. I would recommend you Shift mode (1) with a Toggle, it does this job perfectly and is used in our default config for PS4 Remote Play that has to turn mouse off.
