Shift modifier no disabling gyro
  • Shift modifier no disabling gyro
    I have a shift modifier on the Shoulder R button on a dualsense. The shift 1 layer mapping is set to unmap the gyro, but it is not working (while the R shoulder is pressed) for some reason. The gyro stays enabled. Any ideas?
    Shift layer is another layer for your gamepad, I mean, if you want some feature to work in another shift layer, corresponding mapping should be added to the shift layer as well.
      I want the gyro to be disabled in the shift layer, but it's not working (unmap is not being applied). Seems like a bug.
        Inside Shift, you need to set all Gyro directions to "Do not inherit". This way, you will remove all inherited mappings from the Main layer:
        Could you please try it?
          Great to hear! May I suggest as a feature request that setting to 'unmap' should do the same? It would be much more intuitive for a new user like me to have it that way. Thanks!
            Sure. Will try to make it in one of the next versions.
              Hello there!
              Your suggestion was implemented in the reWASD 5.7 version. Please feel free to check it out!
              It is available for download from our official website.
                Nice, thanks a ton!
                  Originally Posted by flowerdealer View Post
                  Nice, thanks a ton!
                  Always happy to help!
