Hi, I have a question because at tournaments rewasd does not work for me translators I play on the mouse and I use rewasd to have an aim assistant in fortnite but when I start rewasd it does not work during tournaments aim asist and input from rewasda I have and senses but aim asist does not work and I had on my friends have the same problem is there any way to make rewasd work like in the arena?
Need help with fortnite
Hi, I have a question because at tournaments rewasd does not work for me translators I play on the mouse and I use rewasd to have an aim assistant in fortnite but when I start rewasd it does not work during tournaments aim asist and input from rewasda I have and senses but aim asist does not work and I had on my friends have the same problem is there any way to make rewasd work like in the arena? -
Hi, we've had similar reports about fortnite tournaments ignoring inputs from reWASD's virtual gamepad it's either something fortnite developers did intentionally or you're missing some option in the game try checking if an option to lock/ignore certain types of controllers is enabled somewhere or you can ask fortnite support team your question as reWASD only remaps stuff and we have no intention to override or avoid any in-game limitations especially if those are aimed to prevent usage of our software in them.
