How to configure Rapid Fire?
  • How to configure Rapid Fire?
    Actually i emulate a controller with K&M. When i click on Left Shift it use L3 controller button.
    I want to double click on LShift with only one LShift click, how can i do this ?
    Thanks in advance
    Hello. You can do this with the Combo feature. Assign two consecutive presses of the desired key to the combo. You can read more about this here (link).
      If you want to make a double click on the physical key to get L3 button pressed, you should use activators (double press). Please check it in case I am not missing something in your request
      The Double Press could be set there:
        I try like that but it doesn't work. I want with ONE Lshift press to press TWO L3, how can i do?
          You are doing it right. Do you have both Combo and Advanced mapping features?
            Your steps are already very accurate, so you don't have to change anything. drift boss​
